Description:
The dataset hosted on this website contains the information that our crawler, Crawleth, gathered on the Ethereum peer-to-peer network during the period from September 1 to September 30, 2021. All the IP addresses have been anonymized using a salted SHA256 hash and the last byte of the address is set to 0.
All the files in the dataset are JSON files with the same format.
Format:
"stats" is the object containing general information about the current crawl
- "aggregated_crawls": number of crawls that are aggregated in this file
- "original_filenames": name of the aggregated files (date is UTC+0)
- "up_count": number of online nodes gathered
"up" is the list of nodes gathered by Crawleth. There are several nested objects
- "IP address": is a list [hash of the IP address, IP address which last byte is set to 0]
- "UDP port"
- "Seen node IDs": a list of seen NodeID for this IP-port association
- "as": Autonomous System Organization
- "asn": Autonomous System Number
- "city"
- "country"
- "country_code"
- "latitude"
- "longitude"
Acknowledgment:
This dataset is part of a project that has received funding from the European Union’s Horizon 2020 research and innovation programme under grant agreement No 830927.
Contact:
For more information, you can contact the author of this work:
Jean-Philippe Eisenbarth
jean-philippe.eisenbarth(at)loria.fr
Thibault Cholez
thibault.cholez(at)loria.fr
Olivier Perrin
olivier.perrin(at)loria.fr
![](logo.png)
